Webcast-Catalyst9k
Catalyst 2950 - 802.3 protocol interface
Is it possible to change the interface to 802.2? If so, how? Thanks.
Val
Re: Catalyst 2950 - 802.3 protocol interface
You mean to forward IEEE 802.2 (Novell, e.g.) frames?
It should work with no change.
Milan
we have older switches that only support 802.2.
Can you provide some details?
What vendor and type are the older switches?
What happens when you connect the older switch to 2950?
Milan
132
