Webcast-Catalyst9k
Catalyst 2950 bandwidth limitation
please, can anyone tell me if it is possible to limit bandwidth on Catalyst 2950 switch on per VLAN basis.
Thanks in advance.
Maxime Frolov
Re: Catalyst 2950 bandwidth limitation
Hi Maxime,
You can set the rate-limiting or bandwidth limiting on 2950 as such.
regards,
-amit singh
Hello Amit,
I'll try to clarify my problem. I have a 2950 (Standard Image) with a giga uplink to a 6500. On the 2950 I have a VLAN composed of 4 ports. I' like to limit the use of the uplink link of this VLAN or at least of one port to 20%. Would it be possible on 2950 SI or I'll have to upgrade to EI whitch implyes hardware changes ? Or it just impossible on 2950 and I'll have to migrate to 3750 ?
Regards.
Maxime Frolov
127
