Community Member
Catalyst 2950 port security problem
I have a CaAT 2950 and I want to configure port security on Fast Eth ports.
I´ve done the following config:
interface FastEthernet0/1
switchport mode access
switchport port-security
no ip address
spanning-tree portfast
In the documentation in Cisco the say that - switchport port-security violation shutdons and switchport port-security maximum 1 - in the default config of the ports, but I gave that comands anyway. When I connect a PC to this port it appears is MAC but if I connect another PC the port doens´t shutdown.
In conclusion:
port doesn´t shitdown when a new MAC connects to the port.
Antonio Sobreiro
1 REPLY
Community Member
Re: Catalyst 2950 port security problem
I have met this problem too. I suppose it is a matter of
IOS version. By some versions seems to be "Clear (MAC) Address
on Link Down" default configuration.
I am using 12.1(12c)EA1 now and have no problems.
Tomas
93
