Community Member
Catalyst 2950 Series - Monitoring Port
Do the catalyst 2950 series have a port that can be used to connect a device that is designed to monitor all traffic on the switch - we are looking to install Webspy to track network & internet usage. The Sentinal product would best be connected to the switch where it can record all traffic - it needs a monitor port or some such equivalent.
1 REPLY
Purple
Re: Catalyst 2950 Series - Monitoring Port
The 2950 does indeed support that - the functionality is called Switch Port Analyzer (SPAN). The following link has details on how to configure it:
http://www.cisco.com/en/US/products/hw/switches/ps628/products_configuration_guide_chapter09186a00800d84c5.html
Hope that helps - pls rate the post if it does.
Paresh
95
