03-26-2004 01:16 AM - edited 03-02-2019 02:34 PM
We have some Catalyst 2950C-24 in our network. Some of them seem to have problems. Whenever I shut down a fiber interface the other side of the link doesn't recognize that and stays up. The same problem is with reloading the switches (no link down at the other side). The 2950C-24s are connected to Cat 6509s and Cat 4506s. It doesn't matter to wich Core-Switch they are linked. The problem only appears to some of the switches, the others are working properly. The IOS is the same on all switches (12.1(19)EA1a). Is there any idea.
03-27-2004 03:42 AM
I think you can set the link negotiation mode using CMSAD which may cure your link problem. Although, if the links are still look up maybe they were in blocking state from STP already and won't figure it out for a while (50 secs).
R/S
DAve
03-30-2004 06:04 AM
Hi Dave,
I can't set the link negotiation mode. There seem to be no options to configure these physical parameters.
regards
Roman
