Bronze
Catalyst 2950C-24 switches
Can I connect two 2950C-24 switches with 100base_FX ports.
Can any one please assist me in this.
Thank you
Re: Catalyst 2950C-24 switches
Yes you can. All you need is a fiber patch cable with SC connectors. Unless they are in different locations, then you will need 2 fiber patch cables. If you don't get a link light at first switch the connectors. Example if the connectors are red and black. Plug the black in the left port and the red in the right port. Make sure that the other end of the fiber connection is reversed. Red then Black. Hope this helps. Email me at bolds@trammellcrow.com if you have any other issues, I might be able to help.
Bronze
Thank you very much .
118
