05-20-2006 01:48 PM - edited 03-03-2019 03:17 AM
I reloaded the stock configuration onto my Cisco Catalyst 3500XL switch (WS-C3524-XL-EN), through the document titled "Recovering Catalyst Fixed Configuration Switches from a Corrupted or Missing Image". Having successfully transferred the image using, and issued the boot flash:c3500xl-120-5-wc15.bin command, the switch reports
Loading "flash:c3500xl-120-5-wc15.bin"... ###
File "flash:c3500xl-120-5-wc15.bin" uncompressed and installed, entry point: 0x3000
executing...
It's been hanging at executing for 1h 01m 33s. How long is this supposed to take?
05-20-2006 05:02 PM
Shouldn't stay at that point more 30-60 seconds , you have something else going on .
05-20-2006 08:54 PM
Any potential suggestions for a 'next step'?
05-20-2006 06:58 PM
Why did you rename the image file in flash memory?
05-20-2006 08:52 PM
The initial xmodem upload failed, with the switch telling me that the filename provided was too long (max length 45 characters). When I recounted, it wasn't, but I figured that the switch knew more than I did at that point, so I shortened the filename. I did attempt a second time with the original image name, and the upload failed again.
