Catalyst 3524/3548 xl cannot log on using telnet or console help!!!
i have about 30 catayst 3500's and about half have all of a sudden gone haywire and wont let me log on with telnet all it does is this
password
password
password
% Bad Passwords
i can get on with the java aplet and web admin, i know how to do password recovery but is there an easier remote way of fixing this. any ideas?
1 REPLY
Re: Catalyst 3524/3548 xl cannot log on using telnet or console
Unfortuantely if you are getting failed password then you will need to do password recovery - or if you can access via the Java applet you maybe able to change the password from there. Either way your password has been changed and you will need to change it.
136
