catalyst 3524 and nic problems
Hi, i've one catalyst 3524, i'm having problems connecting some nic's,
when i connect one Netelligent 10/100 tx to the switch forcing 100/full duplex in both sides i get time outs and the link keep going up/down, in auto i have no problems but i get a 10 mbps connection, i already switch the cables,
Any suggestions?
thanks
Re: catalyst 3524 and nic problems
Does this happen if you move to another port on the switch, alot of these errors are down to driver versions for the NIC/OS.
It sounds like a faulty NIC card or dodgy driver version, it might be worth your while testing the NIC out on a fast hub or some othervendor switch.
I would look at upgrading the drivers on the nic cards as indicated. Also hardset speed and duplex on both nic and switch, then add this command to the interface on the switch to see if it helps: conf t, int fa 0/xx, carrier-delay 4, end, wr mem......
95
