Attention: The Cisco Support Community site will be in read only mode on Dec14, 2017 from 12:01am PST to 11:30am for standard maintenance. Sorry for the inconvenience.
Catalyst 3548XL with Intel Pro 10/100
Is there any incompatibility with this kind of NIC Card at 100 Meg?
Re: Catalyst 3548XL with Intel Pro 10/100
I think it's compatible. However, sometimes I found that Cisco autonegotiation with some 10/100M network card would choose 10M and half-duplex. If so, set the Cisco port with 100M and full-duplex instead of autonegotiation.
You can check for any compatibility issues on CCO at
http://www.cisco.com/warp/public/473/46.html
Thanks to all for your answers!
I already check all recommandations described in the document referenced for
the NIC compatibility issues.
... all these tests ended badly. There was a little gain with the
parameter carrier-delay set to 4 but still the link goes down.
My port setting is Full duplex and 100 Meg Speed.
With 10 Meg I didn't have any problems! Any Idea of what can be wrong?
98
