08-21-2006 11:33 AM - edited 03-03-2019 04:37 AM
I am unable to telnet, ping, or http into a switch. Although I am able to telnet within switch to switch and ping within also.
I've bounced the switch, made sure I hade enable secret, config line vty, login, password.
I dont know what I am missing on this switch. Any suggs?
08-21-2006 11:41 AM
could be almost anything , may have to post configs .
08-21-2006 11:52 AM
Current configuration : 7761 bytes
version 12.2
no service pad
service timestamps debug datetime localtime
service timestamps log datetime localtime
service password-encryption
hostname SWITCHXXX
enable secret xxx
enable password xxx
no aaa new-model
clock timezone EST -5
clock summer-time EDT recurring
ip subnet-zero
ip routing
no file verify auto
spanning-tree mode pvst
vlan internal allocation policy ascending
interface GigabitEthernet0/1
switchport access vlan 36
switchport mode access
spanning-tree portfast
spanning-tree bpdufilter enable
interface GigabitEthernet0/2
interface GigabitEthernet0/3
interface Vlan1
ip address 10.121.X.XXX 255.255.255.0
ip classless
ip http server
control-plane
line con 0
password xxx
login
line vty 0 4
password xxx
login
line vty 5 15
password xxx
login
end
08-21-2006 11:56 AM
From your partial config, it seems all switchports are placed on VLAN36, however I don't see a SVI with VLAN36 on this switch.
VLAN1 contains the only SVI. You need to create a SVI for VLAN36 and assign an IP within the VLAN36 subnet.
Please rate helpful posts
08-21-2006 12:06 PM
What is SVI?
I have the same setup every where else on my network. I have compared this configuration and I even have a second switch connected to this one who is the secondary link and I am able to telnet, ping it.
08-21-2006 12:15 PM
SVI = Switch Virtual Interface
You have one created for VLAN1, per your config:
interface Vlan1
It seems you aren't using VLAN1 SVI anywhere so do the following:
conf t
int vlan 1
shut
int vlan 36
ip address [enter VLAN1 IP here]
exit
you should be able to ping now.
Do this from the switch while connected via console.
08-21-2006 12:20 PM
SVI means Switched Virtual Interface. The config
interface Vlan1
ip address ...
f.e. is a SVI. It might be a routing issue. Did you define a default gateway in the switch providing you a headache? It might just be, that the switch does not "know" how to send IP packets back to the senders IP (likely not on the same subnet as VLAN1?).
Can you simply check, whether you are able to ping any IP outside the VLAN1 subnet from the switch?
Hope this helps! Please rate all posts.
Regards, Martin
08-22-2006 05:26 AM
I've defined a gateway:
interface Vlan1
ip address 10.121.X.XX 255.255.255.0
no ip route-cache
ip default-gateway 10.121.X.X
ip classless
ip http server
I am still unable to ping it or anyone else from it. BTW: The switch is running fine. Everyone is still connected and operating.
08-22-2006 05:55 AM
use "ip default-gateway x.x.x.x" and no ip routing to define the gateway IP. The gateway IP must be within the subnet of your switch.
Details for static configuration can be found at "Configuring a Gateway of Last Resort Using IP Commands"
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a0080094374.shtml
A second option is to enable dynamic routing protocols like RIPv2 or EIGRP.
A third option is to create a separate SVI for each VLAN you have.
Regards, Martin
08-22-2006 06:03 AM
Did you try my suggestion ?
conf t
int vlan 1
shut
int vlan 36
ip address [enter IP that is under VLAN 1 here]
exit
08-22-2006 09:04 AM
where is your IP routing implemented to get traffic between the different VLANs back and forth? Anyhow, as you have a Layer3 switch it can do the IP routing itself; you can try:
ip routing
interface Vlan1
ip address 10.121.1.1 255.255.255.0
interface Vlan46
ip address 10.121.46.1 255.255.255.0
Adjust IP addresses and VLAN interfaces to your environment.
At the moment I suppose either packets are not reaching the switch, or the way back is not known.
Regards, Martin
08-22-2006 10:25 AM
I'm pretty sure, not 100% but this is a Layer2 switch.
We have our core router routing all IP's.
VLAN 46 is already defined in the core router.
Is it safe to erase running-config and start all over? Is it possible there is something hidden?
08-22-2006 11:16 AM
You have 'ip routing' enabled but you aren't routing any user traffic and switch is acting as a mere layer2 switch.
All the users are on vlan 36. Your management vlan appears to be vlan 1. If you want this switch to forward traffic for both VLANs to your core switch then you need to have a trunk connection core switch. It doesn't appear that you have a trunk to your core based on the posting.
Hence, your choices are,
1. create a trunk to core switch - thus forward traffic for both vlan 1 and vlan 36
(or)
2. configure vlan 36 interface in the switch and assign it an IP address from vlan 36 IP range to get IP connectivity to manage this switch.
Hope that helps!
Sundar
08-22-2006 11:51 AM
Hi everyone,
thank you for all replying I have found the answer!
I had ip routing in the configuration, as soon as I took that command line out I was able to ping the switch and telnet.
08-22-2006 05:53 PM
Do you have a backdoor for the VLAN1 to connect to the router ? e.g. a switch port configured with VLAN 1 and connect to the router. Please advise how VLAN36 can forward the IP w/o require the SVI.... Thx.
