Catalyst 3750-X Switch Recovery
Hello
I booted my Catalyst 3750-X Series and i get the following errror;
Using driver version 3 for media type 1
Invalid parameter block -- no mac address available.
Xmodem file system is available.
Can't set variable with illegal char "▒" (0xffffffff) in name.
Can't set variable with illegal char "▒" (0xfffffff7) in name.
Can't set variable with illegal char "▒" (0xffffffef) in name.
Can't set variable with illegal char "▒" (0xffffffe7) in name.
Can't set variable with illegal char "▒" (0xffffffdf) in name.
Can't set variable with illegal char "▒" (0xffffffd7) in name.
Can't set variable with illegal char "▒" (0xffffffcf) in name.
Can't set variable with illegal char "▒" (0xffffffc7) in name.
Can't set variable with illegal char "▒" (0xffffffbf) in name.
Can't set variable with illegal char "▒" (0xffffffb7) in name.
Can't set variable with illegal char "▒" (0xffffffaf) in name.
Can't set variable with illegal char "▒" (0xffffffa7) in name.
Can't set variable with illegal char "▒" (0xffffff9f) in name.
Can't set variable with illegal char "▒" (0xffffff97) in name.
Can't set variable with illegal char "▒" (0xffffff8f) in name.
Can't set variable with illegal char "▒" (0xffffff87) in name.
Can't set variable with illegal char " (0x7f) in name.
Can't set variable with illegal char "▒" (0xfffffff4) in name.
Can't set variable with illegal char "/" (0x2f) in name.
Can't set variable with illegal char "'" (0x27) in name.
Can't set variable with illegal char "" (0x1f) in name.
Can't set variable with illegal char "" (0x17) in name.
Can't set variable with illegal char "" (0x0f) in name.
Can't set variable with illegal char "" (0x07) in name.
The password-recovery mechanism is enabled.
The "MAC_ADDR" environment variable is not set.
Initializing Flash...
mifs[2]: 1 files, 1 directories
mifs[2]: Total bytes : 6838272
mifs[2]: Bytes used : 1956352
mifs[2]: Bytes available : 4881920
mifs[2]: mifs fsck took 1 seconds.
...done Initializing Flash.
done.
Loading ""...: no such device
Error loading ""
Interrupt within 5 seconds to abort boot process.
Boot process failed...
The system is unable to boot automatically. The BOOT
environment variable needs to be set to a bootable
image.
when i run the command flash_init and boot, this is what i also get
switch: flash_init
...The flash is already initialized.
switch: boot
Error loading ""
switch:
and this is what i get when i run dir
switch: dir
List of filesystems currently registered:
bsdcs[0]: (read-only)
bstage[1]: (read-only)
fstage[2]: (read-write)
xmodem[3]: (read-only)
null[4]: (read-write)
tftp[5]: (read-only)
i need assistance to get the switch working
VIP Purple
How did this happen was it
How did this happen was it working and just shut down ?
flash could be  loose or have a defect in hardware and crashed
a way around it is put a usb in it with an image on it and boot from the usb instead of booting from flash , that should get you back up and running
fixing the flash issue you may have to log it with Cisco it could need an RMA
Yes it was working and it
Yes it was working and it just shut down
i tried booting from a usb it did not work.
VIP Purple
Oh that's not good then it
Oh that's not good then it maybe gone , if it wont boot from flash or usb there the 2 options you have, bootloader may have went , is it under support ? these X series usually have lifetime warranty support with Cisco
No it's not under support
Hall of Fame Super Gold
Show us the error messages when you try to boot using USB.
This the command the error i
This the command the error i get;
switch: boot usbflash0:c3750e-ipbasek9-mz.150-2.SE10a.bin
Loading "usbflash0:c3750e-ipbasek9-mz.150-2.SE10a.bin"...@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
File "usbflash0:c3750e-ipbasek9-mz.150-2.SE10a.bin" uncompressed and installed, entry point: 0x3000
executing...
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Cisco IOS Software, C3750E Software (C3750E-IPBASEK9-M), Version 15.0(2)SE10a, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2016 by Cisco Systems, Inc.
Compiled Thu 03-Nov-16 13:43 by prod_rel_team
HULC:Collect Entropy thread starting on box...
Initializing flashfs...
Can't set variable with illegal char "" (0xFFFFFFFF) in name.
...done Initializing flashfs.
Checking for Bootloader upgrade..
Boot Loader upgrade not required (Stage 2)
FIPS: Fatal failure: sp800108 failed
%Software-forced reload
00:00:20 UTC Mon Mar 1 1993: Unexpected exception to CPUvector 2000, PC = 26E6028
-Traceback= 0x26E6028z 0x213674Cz 0x2136060z 0x1C56794z 0x1C56954z 0x1C56A70z 0x510A48z 0x510CB0z 0x26E730Cz 0x26E18C0z
00:00:20 UTC Mon Mar 1 1993: Unexpected exception to CPUvector 2000, PC = 26E72E8
-Traceback= 0x26E72E8z
=== Flushing messages (00:00:20 UTC Mon Mar 1 1993) ===
Buffered messages:
Queued messages:
*Mar 1 00:00:20.543: %SYS-3-LOGGER_FLUSHING: System pausing to ensure console debugging output.
*Mar 1 00:00:17.439: Read env variable - LICENSE_BOOT_LEVEL =
*Mar 1 00:00:17.439: %LICENSE-2-VLS_ERROR: 'VLSaddLicenseStorage' failed with an error - rc = 145 - 'Error[145]: Failure in creating/opening the store.'
-Traceback= 5012F4z 3A214z 82B0z 510810z 510CB0z 26E730Cz 26E18C0z
*Mar 1 00:00:17.439: %HULC_LICENSE-1-LICENSE_REGISTER_FAILED: license register license storage 'flash:' failed - rc = 24
*Mar 1 00:00:17.448: %IOS_LICENSE_IMAGE_APPLICATION-6-LICENSE_LEVEL: Module name = c3750x Next reboot level = lanbase and License = No valid license found
Debug Exception (Could be NULL pointer dereference) Exception (0x2000)!
SRR0 = 0x01C98368 SRR1 = 0x00029230 SRR2 = 0x026E6028 SRR3 = 0x00029230
ESR = 0x00000000 DEAR = 0x00000000 TSR = 0x84000000 DBSR = 0x10000000
CPU Register Context:
Vector = 0x00002000 PC = 0x026E6028 MSR = 0x00029230 CR = 0x35003033
LR = 0x026E5FC4 CTR = 0x004ED8D8 XER = 0xA0000012
R0 = 0x026E5FC4 R1 = 0x04CD1478 R2 = 0x00000000 R3 = 0x041DAF3C
R4 = 0x00000000 R5 = 0x00000000 R6 = 0x04CD1448 R7 = 0x041B0000
R8 = 0x00029230 R9 = 0x041B0000 R10 = 0x00029230 R11 = 0x00000000
R12 = 0x35003039 R13 = 0x0B981A10 R14 = 0x00510C68 R15 = 0x00000000
R16 = 0x00000000 R17 = 0x00000000 R18 = 0x00000000 R19 = 0x00000000
R20 = 0x00000000 R21 = 0x00000000 R22 = 0x00000000 R23 = 0x00000000
R24 = 0x00000000 R25 = 0x00000000 R26 = 0x04CD1518 R27 = 0x03DB0000
R28 = 0x00000009 R29 = 0x04111EBC R30 = 0x03DAF888 R31 = 0x00000000
Stack trace:
PC = 0x026E6028, SP = 0x04CD1478
Frame 00: SP = 0x04CD1488 PC = 0x026E5FC4
Frame 01: SP = 0x04CD1490 PC = 0x0213674C
Frame 02: SP = 0x04CD1498 PC = 0x02136060
Frame 03: SP = 0x04CD14A8 PC = 0x01C56794
Frame 04: SP = 0x04CD14C8 PC = 0x01C56954
Frame 05: SP = 0x04CD14E0 PC = 0x01C56A70
Frame 06: SP = 0x04CD1510 PC = 0x00510A48
Frame 07: SP = 0x04CD1618 PC = 0x00510CB0
Frame 08: SP = 0x04CD1620 PC = 0x026E730C
Frame 09: SP = 0x00000000 PC = 0x026E18C0
Switch uptime is 23 seconds
cisco WS-C3750X-48P (PowerPC405) processor with 262144K bytes of memory.
Can't set variable with illegal char "ÿ" (0xffffffff) in name.
Can't set variable with illegal char "÷" (0xfffffff7) in name.
Can't set variable with illegal char "ï" (0xffffffef) in name.
Can't set variable with illegal char "ç" (0xffffffe7) in name.
Can't set variable with illegal char "ß" (0xffffffdf) in name.
Can't set variable with illegal char "×" (0xffffffd7) in name.
Can't set variable with illegal char "Ï" (0xffffffcf) in name.
Can't set variable with illegal char "Ç" (0xffffffc7) in name.
Can't set variable with illegal char "¿" (0xffffffbf) in name.
Can't set variable with illegal char "·" (0xffffffb7) in name.
Can't set variable with illegal char "¯" (0xffffffaf) in name.
Can't set variable with illegal char "§" (0xffffffa7) in name.
Can't set variable with illegal char "" (0xffffff9f) in name.
Can't set variable with illegal char "" (0xffffff97) in name.
Can't set variable with illegal char "?" (0xffffff8f) in name.
Can't set variable with illegal char "" (0xffffff87) in name.
Can't set variable with illegal char "" (0x7f) in name.
Can't set variable with illegal char "ô" (0xfffffff4) in name.
done.
Error loading ""
image.
switch:
Ok, we're getting somewhere.
  1. Try a different IOS version other than 15.0(2)SE10a.
  2. If there is an expansion module installed, remove it before loading the IOS.
  3. If there is a configuration, rename the configuration file while in ROMmon so the switch will boot without any configuration.
1. A different IOS version ?
1. A different IOS version ? Lower or Higher ?  What will you suggest?
2. There is no expansion module installed
3. Is there an alternative way of getting into ROMmon because i can't get into it?
Do you really need features only found in 15.0(2)SE?  IF not, then use 12.2(55)SE11.
So i ran the IOS 12.2(55)SE11
So i ran the IOS 12.2(55)SE11 and this is the result i got;
Cisco IOS Software, C3750E Software (C3750E-IPBASEK9-M), Version 12.2(55)SE11, R ELEASE SOFTWARE (fc3)
Compiled Wed 17-Aug-16 12:19 by prod_rel_team
SRR0 = 0x0135CEC8 SRR1 = 0x00029230 SRR2 = 0x01F1395C SRR3 = 0x00029230
Vector = 0x00002000 PC = 0x01F1395C MSR = 0x00029230 CR = 0x59000093
LR = 0x01F13920 CTR = 0x0130A5E4 XER = 0x80000013
R0 = 0x01F13920 R1 = 0x03EEDD20 R2 = 0x00000000 R3 = 0x00000000
R4 = 0xFFFFFFFE R5 = 0x00000000 R6 = 0x03EEDD08 R7 = 0x00000000
R8 = 0x00000000 R9 = 0x033F5E64 R10 = 0x033D0000 R11 = 0x00000000
R12 = 0x0000434F R13 = 0x0B981A10 R14 = 0x00409AF0 R15 = 0x00000000
R24 = 0x00000000 R25 = 0x00000000 R26 = 0x00000000 R27 = 0x00000000
R28 = 0x00000009 R29 = 0x00000000 R30 = 0x03EEDD38 R31 = 0x00000000
Stack trace:
PC = 0x01F1395C, SP = 0x03EEDD20
Frame 00: SP = 0x03EEDD30 PC = 0x01F13920
Frame 01: SP = 0x03EEDD50 PC = 0x017E557C
Frame 02: SP = 0x03EEDD58 PC = 0x0133709C
Frame 03: SP = 0x03EEDD70 PC = 0x01337134
Frame 04: SP = 0x03EEDD90 PC = 0x004098E4
Frame 05: SP = 0x03EEDE98 PC = 0x00409B50
Frame 06: SP = 0x03EEDEA0 PC = 0x01F15AEC
Frame 07: SP = 0x00000000 PC = 0x01F0C2C0
Switch uptime is 2 hours, 37 minutes, 23 seconds
02:37:23 UTC Mon Mar 1 1993: Unexpected exception to CPUvector 0, PC = 135CEC8
-Traceback= 135CEC8 1D6C064
Stack trace:
Switch uptime is 2 hours, 37 minutes, 25 seconds
So the switch stayed up for more than two hours before crashing.
I think this is a hardware fault and the appliance needs to be RMA-ed.
104
