Community Member
catalyst 4000 devices are listed as uncertified systems in DFM 1.2
All my catalyst 4000 switches are grouped as uncertified system instead of switches. Do I need a patch for DFM?? If so, wich one do I need??
Blue
Re: catalyst 4000 devices are listed as uncertified systems in D
Have you applied the DFM 1.2 IDU 1.2.4 patch from CCO:
http://www.cisco.com/cgi-bin/tablebuild.pl/cw2000-dfm
Most of the new switches are supported with the above IDU per:
http://www.cisco.com/univercd/cc/td/doc/product/rtrmgmt/cw2000/dfm/dev_sup/dfm1_2.htm#60303
Community Member
Thank you, I have installed this patch and only one device is regrouped as a switch. It is a catalyst 4503, but I have a Catalyst 4506 and a Catalyst 4006 device that remain as "uncertified system".
The sysobjectID for the Catalyst 4006 is "1.3.6.1.4.1.9.1.448" but this is not listed in the devices supported with IDU 1.2.4
Blue
.448 is the sysObjectID for Sup-IV (WS-X4515). Does this Cat4006 has WS-X4515 in it?
Community Member
No. It has a X4014 (SUPIII), and the other catalyst device (WS - C4506) has a WS -X 4013 (SUP II). Could this be the problem??
Blue
From: http://www.cisco.com/univercd/cc/td/doc/product/rtrmgmt/cw2000/dfm/dev_sup/dfm1_2.htm
Note 3 says, DFM supports the Catalyst 4000/4500 Supervisor Engine IV (WS-X4515) on the C4503, C4506 and C4507. DFM supports the Catalyst 4000 Supervisor Engine III (WS-X4014) on the C4503 and C4506.
Community Member
Yes, but what should i do if the systemobjectID doesn´t appear in the list of supported devices by IDU 1.2.4 ??
Blue
Then it's not supported by IDU 1.2.4
81
