Webcast-Catalyst9k
Catalyst 4006 inline power tp not connect with realtek chipsets
We have Cat 4006 switches with inline power tp mods. These will not connect with several realtek integrated chipset ( RTL8139 )based ethernet interfaces on several vendors pc's including HP(Compaq), E-machines, Sony.
Has anybody seen this and reached a solution ( besides buy a netgear card ?
tia,
jg
some info follows :
Mod Slot Ports Module-Type Model Sub Status
1 1 2 1000BaseX Supervisor WS-X4013 no ok
2 2 0 Switch Fabric Module WS-X4019 no ok
3 3 48 Inline Power Module WS-X4148-RJ45V no ok
4 4 48 Inline Power Module WS-X4148-RJ45V no ok
5 5 48 Inline Power Module WS-X4148-RJ45V no ok
6 6 48 Inline Power Module WS-X4148-RJ45V no ok
WS-C4006 Software, Version NmpSW: 6.1(1)
Copyright (c) 1995-2000 by Cisco Systems, Inc.
NMP S/W compiled on Sep 30 2000, 12:25:52
GSP S/W compiled on Sep 28 2000, 18:28:28
System Bootstrap Version: 5.4(1)
Hardware Version: 3.2 Model: WS-C4006 Serial #: JAB05190AM2
Mod Port Model Serial # Versions
1 2 WS-X4013 JAB05190AM2 Hw : 3.2
Gsp: 6.1(1.0)
Nmp: 6.1(1)
2 0 WS-X4019 JAB05060N06 Hw : 1.0
3 48 WS-X4148-RJ45V JAB05190F1M Hw : 1.5
4 48 WS-X4148-RJ45V JAB05190C0K Hw : 1.5
5 48 WS-X4148-RJ45V JAB05190C82 Hw : 1.5
6 48 WS-X4148-RJ45V JAB05190C8R Hw : 1.5
Bronze
Re: Catalyst 4006 inline power tp not connect with realtek chips
I am not sure if there is another way out. Refer to the data sheets of the prodcuts to see if you can find something. http://www.cisco.com/pcgi-bin/Support/browse/psp_view.pl?p=Hardware:Cat4000&viewall=true
Can you try disabling inline power if you are not using it? Also, if you can upgrade the CAT OS. You are running 6.1(1) which was the first release in 6.x and is no longer supported. 6.4(6) which is general deployment should be good. Read the release notes to check for known issues
al
Have anybody another ideas? I have the same problem with realtek NICs and c6500 with WS-X6148-RJ45V card.
Turn off the inline power didn't help.
I have the following versions:
3 48 WS-X6148-RJ45V SAL0727FZTS Hw : 1.4
Fw : 5.4(2)
Sw : 8.1(2)
WS-F6K-VPWR Hw : 2.0
Sw : 0.0(0)
125
