Catalyst 4006 ,Interface VLAN down,
hungnm
Hi all,
I have trouble :
I configured VLAN interfaces for catalyst 4006 (VLAN 2, VLAN 3, VLAN 4, VLAN 5, VLAN 6) , each interface have one network IP address, the networks routing by RIP.
The Catalyst 4006 runing normaly.
But today i can not ping VLAN 6, after sh VLAN Interface i saw that:
VLAN interface up , line protocol down,
VLANs remain is normaly
I don't understand why ?
Pls help me resolve this problem.
Thank you very much
Hung, CCNA, Fujitsu
5 Replies 5
vincent-n
Level 3
Level 3
What version of OS are you using? Are you still using separate CatIOS for the Catalyst and IOS for the router/L3 routing module?
My Catalyst use
IOS (tm) Catalyst 4000 L3 Switch Software (cat4000-IS-M), Version 12.1(8a)EW1.
I know this old version, I don't know this version effect to catalyst activity .
Thanks for help me.
see you
vincent-n
Level 3
Level 3
BTW, I'm running Cat4006 with L3 routing module (and also external 3662) router at the moment so I can most probably help you out with your problem.
Prashanth Krishnappa
Do you have any active ports in VLAN6? If not the L3 VLAN interface will shut down due to auto-state
http://www.cisco.com/warp/public/473/188.html
ipotts
You need to create the vlan in the vlan database.
Please do.
conf t
vlan 1-6
state active
end
Ian
