Catalyst 4006 ,Interface VLAN down,
Hi all,
I have trouble :
I configured VLAN interfaces for catalyst 4006 (VLAN 2, VLAN 3, VLAN 4, VLAN 5, VLAN 6) , each interface have one network IP address, the networks routing by RIP.
The Catalyst 4006 runing normaly.
But today i can not ping VLAN 6, after sh VLAN Interface i saw that:
VLAN interface up , line protocol down,
VLANs remain is normaly
I don't understand why ?
Pls help me resolve this problem.
Thank you very much
Hung, CCNA, Fujitsu
Re: Catalyst 4006 ,Interface VLAN down,
What version of OS are you using? Are you still using separate CatIOS for the Catalyst and IOS for the router/L3 routing module?
My Catalyst use
IOS (tm) Catalyst 4000 L3 Switch Software (cat4000-IS-M), Version 12.1(8a)EW1.
I know this old version, I don't know this version effect to catalyst activity .
Thanks for help me.
see you
BTW, I'm running Cat4006 with L3 routing module (and also external 3662) router at the moment so I can most probably help you out with your problem.
Do you have any active ports in VLAN6? If not the L3 VLAN interface will shut down due to auto-state
http://www.cisco.com/warp/public/473/188.html
You need to create the vlan in the vlan database.
Please do.
conf t
vlan 1-6
state active
end
Ian
180
