Community Member
Catalyst 4006 L3 and L2 problem
I have just brought up a Cat 4006 switch up with WS-4232-L3 module and Sup Engine ii WS-X4013.Configured L2 sc0 interface and L3 module in same vlan, but not able to ping each other's IP address.
Example: IP on L3 portchannel 1.1 is 10.100.1.1
IP on Sc0 of L2 is 10.100.1.2 and sc0 is pointing default to L3 IP.
Anything else to be done.Please help.
Community Member
Re: Catalyst 4006 L3 and L2 problem
My doubt is do I need to connect Gigabit links on L2 and L3 for IP connectivity to be successful. Or since the L3 is internally connected to L2 Backplane. thats enough.
Community Member
This is a tough one. We messed with it forever and even opened a TAC case on it (I looked and looked for the config. we finally came up with but no luck). First take a look at this page, it talks about the L3 blade.
http://www.cisco.com/warp/customer/473/28.html
The L3 Gig ports are router ports (if you try to use them as switch ports with CRB or IRB the results can be unpredictable and inconsistent). They are GIG1 and 2 on the front of the blade. 3 and 4 are internal, they connect to the backplane (on the router side).
What you are trying to do we managed once, but were unable to duplicate when we needed it later on. The TAC will tell you the CRB and IRB are not supported by the 4232-L3 SW. It does say it in the release notes but I tell you it worked once for a converged network test we did. The key was to remove as many of the IPs as you can from the router configs.
The ports that are on the sh port command are the internal switch side connections (mod #/1 and mod#/2). This piece of the router config might help you some. The switch side follows. Some stuff has been deleted but it is all default or our network specfic. If I come across THE config I will post it.
GOOD LUCK
Charlie
bridge crb
interface Port-channel1
no ip address
no ip directed-broadcast
hold-queue 300 in
interface Port-channel1.1
encapsulation dot1Q 1 native
no ip redirects
bridge-group 1
interface Port-channel1.100
encapsulation dot1Q 100
no ip redirects
bridge-group 100
interface FastEthernet1
no ip address
shutdown
interface GigabitEthernet1
no ip address
interface GigabitEthernet1.1
no ip redirects
bridge-group 1
interface GigabitEthernet1.100
no ip redirects
bridge-group 100
interface GigabitEthernet2
no ip address
interface GigabitEthernet2.1
no ip redirects
bridge-group 1
interface GigabitEthernet2.100
no ip redirects
bridge-group 100
interface GigabitEthernet3
no ip address
no negotiation auto
channel-group 1
interface GigabitEthernet4
no ip address
no negotiation auto
channel-group 1
ip classless
arp 127.0.0.2 0030.8510.7400 ARPA
bridge 1 protocol ieee
bridge 100 protocol ieee
The switch side looks like this:
****************** show port ******************
Port Name Status Vlan Level Duplex Speed Type
1/1 connected trunk normal full 1000 1000-LX/LH
1/2 connected trunk normal full 1000 1000-LX/LH
2/1 BACKPLANE connected trunk normal full 1000 No Connector
2/2 BACKPLANE connected trunk normal full 1000 No Connector
#module 1 : 2-port 1000BaseX Supervisor
set trunk 1/1 on dot1q 1-1005
set trunk 1/2 on dot1q 1-1005
#module 2 : 34-port Router Switch Card
set port name 2/1 BACKPLANE
set port name 2/2 BACKPLANE
set trunk 2/1 nonegotiate dot1q 1-1005
set trunk 2/2 nonegotiate dot1q 1-1005
#module 3 : 48-port Inline Power Module
set port disable 3/2,3/4,3/6,3/8,3/10-48
set port speed 3/1 10
set port speed 3/2-48 100
set port duplex 3/1-48 full
set port name 3/1 Gowen_Router
set port name 3/3 BDC_Server
set port name 3/5 Print_Server
set spantree portfast 3/23 enable
#module 4 : 6-port 1000BaseX Ethernet
set trunk 4/1 on dot1q 1-1005
set trunk 4/4 on dot1q 1-1005
set trunk 4/5 on dot1q 1-1005
set trunk 4/6 on dot1q 1-1005
#module 5 : 48-port Inline Power Module
#module 6 empty
Community Member
Here is the config that works.
L2 : set int sc0 1 10.100.1.2/255.255.255.0 10.100.1.255
set ip route 0.0.0.0 0.0.0.0 10.100.1.1
L3: int port channel 1.1
ip address 10.100.1.1 255.255.255.0
encap dot1q 1 native
" native" was missing before.
Thanx for your suggestions.
90
