Hi guys,
trying to find out how to activate Temperature Alarm on
my Cisco Catalyst 4006 using Sup 3 engine. Would like
to configure certain threshold temperature for auto shutdown
to avoid module hardware damage because of inconsistent
temperature. I did a show system at the Cat 4 enable prompt
and temp-alarm status is "off" . How do you turn it "on then ?
Any ideas ?
