Webcast-Catalyst9k
catalyst 4500 Ethernet and fibre channel passthru
dear sir,
anyone have any idea / documentation showing that the belows device 1.) & 2.) can support Ethernet and fibre channel passthru ? thanks.
1.) WS-X4424-GB-RJ4 (Catalyst 4500 24-port 10/100/1000 Module (RJ45)
2.) WS-X4306-GB (Catalyst 4500 Gigabit Ethernet Module, 6-Ports (GBIC)
Silver
Re: catalyst 4500 Ethernet and fibre channel passthru
Could you explain more about the exact requirement ?
WS-X44240GB-RJ45 is a RJ-45 interface module. Cannot support fibre.
WS-X4306-GB is a SC fibre interface module, support fibre and Ethernet only.
Both are Ethernet module and I believe both cannot support fibre channel (passthru).
Hope this helps.
hi jackyoung,
thank you for good reply, any documentation that talks about that?
Silver
You're welcome. Check below for the module info. And there is description about support of fibre channel passthru.
http://www.cisco.com/en/US/products/hw/switches/ps4324/products_data_sheet0900aecd802109ea.html
You can also seach Cisco web for more info.
Hope this helps.
Silver
Sorry. It should be there is NO description of the support of fibre channel passthru.
it's ok.thank you for reply.
540
