Webcast-Catalyst9k
Catalyst 4510R stops forwarding packets
I have a WS-C4510R running 12.2(20)EWA1 with dual SUPs V.
There are also 10/100 48-port network modules and two 10/100/1000 ports with fiber uplinks to the MDF.
Every now and then, this switch will stop forwarding packets. Hosts on the same VLAN and connected to the same NM cannot talk either. If I reboot the switch, then all connectivity is restored. Sometimes, I can wait about 15 mins and the switch will resume operations. No syslogs are logged to indicate any event.
Any ideas?
Re: Catalyst 4510R stops forwarding packets
How often does this happen? Can you capture an output of sh tech when it happens again?
It used to happen once every month or so. However, now it has become more frequent. Last week it did the act like 3 times (2 of them in one day).
When it happens next, we will capture the output of "sh tech".
97
