Catalyst 5500 with Supervisor Engine II MMF with too large config for NVRAM
The Problem is the config is larger than the NVRAM.
To save the config in a different location is what I want to do, but cannot seem to find the commands to allow this.
MGMT-4-OUTOFNVRAM:Out of NVRAM space: (11,11592
,262144,7644) - configuration of one module not saved in NVRAM
The 9th module I have inserted is in fact in slot 11: a WS-X5234
Mod Slot Ports Module-Type Model Sub Status
1 1 2 100BaseFX MM Supervisor WS-X5506 yes ok
3 3 24 10/100BaseTX Ethernet WS-X5224 no ok
4 4 24 10/100BaseTX Ethernet WS-X5234 no ok
5 5 24 10/100BaseTX Ethernet WS-X5234 no ok
6 6 24 10/100BaseTX Ethernet WS-X5234 no ok
7 7 24 10/100BaseTX Ethernet WS-X5234 no ok
8 8 24 10/100BaseTX Ethernet WS-X5234 no ok
9 9 24 10/100BaseTX Ethernet WS-X5234 no ok
10 10 24 10/100BaseTX Ethernet WS-X5234 no ok
11 11 24 10/100BaseTX Ethernet WS-X5234 no ok
MGMT-4-OUTOFNVRAM: Out of NVRAM space: ([dec], [dec], [dec],dec])
Explanation This message indicates that an NVRAM write operation fails due to lack of space. The first [dec] is the configuration block that was being written to NVRAM, the second [dec] is the size of configuration that was being written to NVRAM, the third [dec] is the total NVRAM size in the system, and the fourth
[dec] is the amount of NVRAM space available.
Action Move the ACL configuration to Flash memory, or clear the configuration for modules not in use.
1592 -- the second [dec] is the size of configuration that was being written to NVRAM --> added to the existing config.
7644 -- the fourth [dec] is the amount of NVRAM space available
sh ver of the switch that has the problem ends with.
DRAM FLASH NVRAM
Module Total Used Free Total Used Free Total Used Free
1 32768K 16299K 16469K 8192K 6656K 1536K 256K 249K 7K
Uptime is 9 days, 9 hours, 5 minutes
Any idee's?
Marius
Re: Catalyst 5500 with Supervisor Engine II MMF with too large c
Marius
There was a bug filed for this
http://www.cisco.com/cgi-bin/bugtool/onebug.pl?bugid=CSCdu11952
This bug was closed as it's a hardware limitation. Please check the bug notes for resolution
-Prashanth
Hi Prashanth
Thank you for the reply. This is the info I needed.
Kind regards
Marius
124
