Catalyst 6006 Switch with system light orange and password not recovered
Catalyst 6006 standalone with no connection need to be tested weather it's faulty or ok. When I reboot it has Orange Status light ON all time I remove and put all module but still has same problem. I am trying to Break the password with Break+Cntrl, Confreg 0x2142, reset but after that I will have same promt with old name of router and asking me the password not taking any password first password cisco but with enable doesn't work How can test this switch. Their is no error while rebooting all test pass and ok with Version 5.3(1).
Re: Catalyst 6006 Switch with system light orange and password n
Do you have both power supplies powered up? If you have just one PS plugged in the status light will be amber and Sup will show up faulty. Also use the following password recovery procedure
http://www.cisco.com/warp/public/474/pswdrec_6000.html
If the amber light still stays, paste the output of sh ver and sh system
First problem solve amber light went away after put both power supply on.
Thanks for your help and Thanks for all cisco team
Here is a description of LEDs for your future reference;
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat6000/6000hw/mod_inst/01overvw.htm#11779
R/Yusuf
153
