You may experience some slow load times, errors, and slight inconsistencies. We ask for your patience as we finalize the launch. Thank you.
Catalyst 6500 - monitoring the temperature
When monitoring a Catalyst 6500 temperature, which temperature in the show env temp has to be monitored?
Is it enough to monitor just one of them?
Or shall I monitor all the outputs?
Thanks in advance for any reply.
Alex
  • Other Network Infrastructure Subjects
1 REPLY
Bronze
Re: Catalyst 6500 - monitoring the temperature
You should monitor all of them. In case you did not know, the numbers in parens are the (warning temp, critical temp) settings for that temp sensor.
299
