Catalyst 6500 Supervisor engine issues....
I am getting the following errors when a reset our catalyst 6500:
SCP Communication error with Module 2
2003 May 23 21:16:53 %QOS-3-SETDEFCOSFAIL:Unable to set default CoS on port 2/1. Error code -255
2003 May 23 21:17:02 %QOS-3-SETTRUSTFAIL:Unable to set trust type on 2/1. Error code -255
2003 May 23 21:17:11 %QOS-3-SETDEFCOSFAIL:Unable to set default CoS on port 2/2. Error code -255
2003 May 23 21:17:20 %QOS-3-SETTRUSTFAIL:Unable to set trust type on 2/2. Error code -255
Failed Module Bringup Process
Please Help..
Gold
Re: Catalyst 6500 Supervisor engine issues....
This message indicates that the desired trust type could not be set on the module. [dec]/[dec] is the module number/port number.
Recommended Action: Check the module for hardware problems. If a problem is not obvious, contact your technical support representative.
pretty much sums it up
What module do you have in slot 2? Do you see this only when the module in slot 2 is reset and when it comes online? If so, then there is a minor bug
"Error code -255 when update EPLD on module while it in reset process"
255
