Catalyst 6506/Cisco 7206 VXR Ethernet Error Problem
We have a 2 Cisco 7206 VXR routers and 2 Catalyst 6506 with MSFC/PFC. Each Cisco 7206VXR is connected to a Catalyst 6506 L3 via a 100 Base-T connection. Both configurations are identical and are having the same problem.
Both the 7206 VXR FE interface and the Catalyst 6506 FE interface (6248 blade) are manually set to full duplex, 100Mbps. We're getting input errors on the Catalyst 6506 interface ONLY (see below) and can't figure out what the problem is. No errors are being reported on the 7206VXR. Performance seems fine...we have not seen any latency or timeouts.
Any help would be greatly appreciated!
Catalyst 6506 L3:
FastEthernet2/1 is up, line protocol is up
Hardware is C6k 100Mb 802.3, address is 0030.962e.d808 (bia 0030.962e.d808)
Description: Layer 3 Routed: To border1 Cisco 7206VXR
Internet address is 10.0.0.6/30
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
Keepalive set (10 sec)
Full-duplex, 100Mb/s
input flow-control is off, output flow-control is off
Last input 00:00:00, output never, output hang never
Last clearing of "show interface" counters 00:31:54
Queueing strategy: fifo
Output queue :0/40 (size/max)
5 minute input rate 587000 bits/sec, 64 packets/sec
5 minute output rate 477000 bits/sec, 114 packets/sec
232272 packets input, 145227895 bytes, 0 no buffer
Received 414 broadcasts, 0 runts, 678 giants, 0 throttles
*****678 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored*****
279941 packets output, 139606531 bytes, 0 underruns
0 lost carrier, 0 no carrier
Cisco 7206 VXR:
FastEthernet0/0 is up, line protocol is up
Hardware is DEC21140A, address is 0003.e413.0800 (bia 0003.e413.0800)
Description: Layer 3 Routed: To aus-core1 Catalyst 6506
Internet address is 10.0.0.5/30
Full-duplex, 100Mb/s, 100BaseTX/FX
Last input 00:00:02, output 00:00:00, output hang never
Input queue: 0/75/0/6 (size/max/drops/flushes); Total output drops: 0
5 minute input rate 368000 bits/sec, 122 packets/sec
5 minute output rate 635000 bits/sec, 140 packets/sec
7677087 packets input, 3964834129 bytes
Received 14168 broadcasts, 0 runts, 0 giants, 0 throttles
0 watchdog
10258852 packets output, 1216921938 bytes, 0 underruns
0 output errors, 0 collisions, 2 interface resets
4 lost carrier, 0 no carrier
7206VXR's are running IOS 12.2(7c)
Catalyst's are running Catalyst IOS 12.1(12c) E3
1 REPLY
Re: Catalyst 6506/Cisco 7206 VXR Ethernet Error Problem
Okay, so upon analyzing this closer I see that the input errors are giants. So, the question becomes:
Why is the 7206 sending giants to the 6506? Both have their MTU's set to 1500. Should I mess with the MTU sizes to attempt correct this?
264
