Catalyst 6509 Cat OS to IOS conversion
I'm trying to convert Cat OS to IOS, below are some info:
Hardware information:
Mod Slot Ports Module-Type Model Sub Status
2 2 2 1000BaseX Supervisor WS-X6K-S2U-MSFC2 yes ok
16 2 1 Multilayer Switch Feature WS-F6K-MSFC2 no ok
Mod Module-Name Serial-Num
2 SAL08218H90
16 SAL08218CN0
Mod MAC-Address(es) Hw Fw Sw
2 00-08-7d-cb-ac-ca to 00-08-7d-cb-ac-cb 5.0 7.1(1) 7.6(7)
00-08-7d-cb-ac-c8 to 00-08-7d-cb-ac-c9
00-1e-79-9c-a0-00 to 00-1e-79-9c-a3-ff
16 00-0f-90-98-fa-40 to 00-0f-90-98-fa-7f 2.6 12.1(20)E3 12.1(20)E3
Mod Sub-Type Sub-Model Sub-Serial Sub-Hw Sub-Sw
2 L3 Switching Engine II WS-F6K-PFC2 SAL08218AZ3 3.4
Current OS of Supervisor Engine: cat6000-sup2k8.7-6-7.bin
Current OS of MSFC2: c6msfc2-jsv-mz.121-20.E3.bin
To be upgrade to IOS: c6sup22-js-mz.121-23.E4.bin
I have followed the procedure on Converting Hybrid OS to Native IOS from the web link below:
http://www.cisconetworkingacademy.info/en/US/products/hw/switches/ps708/products_tech_note09186a008015bfa6.shtml#conv_msfc_2
After the switch reboots, it prompts error:
"Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
IOS (tm) c6sup2_sp Software (c6sup2_sp-SPV-M), Version 12.1(27b)E4, RELEASE SOFTWARE (fc3)
Technical Support:
http://www.cisco.com/techsupport
Copyright (c) 1986-2008 by cisco Systems, Inc.
Compiled Fri 29-Feb-08 14:16 by hqluong
Image text-base: 0x40020EF4, data-base: 0x4095A180
00:00:03: %PFREDUN-6-ACTIVE: Initializing as ACTIVE processor
00:00:03: %OIR-6-CONSOLE: Changing console ownership to route processor
System Bo otstrap, Version 12.1(1 1r)E1, RELEASE SOFTWARE (fc1)
TAC Sup port: ht tp:/ /w w w.cisco.com/tac
Copyright (c) 20 02 by cisco Systems, Inc.
Cat6k-MSFC2 platform with 262144 Kbytes of main memory
Download Start
! ! !*** Mistral Interrupt on line 4 ***
System memory 1 bit ECC correctable error interrupt ..
PC = 0x8000840c, Cause Reg = 0x4400, Status Reg = 0x3041c003
Please assist to advise any idea/solution to resolved this. Many Thanks.
Re: Catalyst 6509 Cat OS to IOS conversion
Hey Romel,
This looks like a potential hardware failure with the memory on the SUP, likely specific to the RP side -
Do you see this error each time the SUP tries to boot?  You'll probably need to replace the SUP (at the very least, the MSFC).  Hope this helps.
Brandon
HI Brandon,
Thanks for the reply.
Yes, I do encounter this error everytime I reboot the Sup with IOS. I have another spare of SUP with the same model.
I will try to convert the spare SUP and hope it works. Will let you know of the outcome.
Best Regards,
Romel
Hi Brandon,
As I mentioned, I tested the spare SUP and it work just fine. Indeed it was a hardware problem and is now on the process to be replaced.
Thank you very much for the assistance.
Best Regards,
Romel
932
