Community Member
Catalyst 6509 power-bad status
HI,
I am trying to install a ws-x6148A-GE-TX blade in my 6500, after inserting the blade i get the folowing error from a show enviroment. Can anyone help ?
HubRoom141> (enable) sh environment all
Environmental Status (. = Pass, F = Fail, U = Unknown, N = Not Present)
PS1: . PS2: . PS1 Fan: . PS2 Fan: .
Chassis-Ser-EEPROM: . Fan: .
Clock(A/B): A Clock A: . Clock B: .
VTT1: . VTT2: . VTT3: .
Intake Exhaust Device 1 Device 2
Slot Temperature Temperature Temperature Temperature
1 21C(50C,65C) 28C(60C,75C) 22C 28C
2 18C(50C,65C) 26C(60C,75C) 23C 26C
4 17C(50C,65C) 22C(60C,75C) N/A N/A
5 14C(50C,65C) 21C(60C,75C) N/A N/A
6 15C(50C,65C) 21C(60C,75C) N/A N/A
7 21C(50C,65C) 23C(60C,75C) N/A N/A
8 29C(50C,65C) 32C(60C,75C) N/A N/A
9 23C(50C,65C) 23C(60C,75C) 23C 27C
1 (Switch-Eng) 22C(50C,65C) 25C(60C,75C) N/A N/A
2 (Switch-Eng) 21C(50C,65C) 24C(60C,75C) N/A N/A
1 (MSFC) 23C(50C,65C) 29C(60C,75C) N/A N/A
2 (MSFC) 20C(50C,65C) 25C(60C,75C) N/A N/A
Chassis Modules
VTT1: 19C(85C,100C)
VTT2: 19C(85C,100C)
VTT3: 24C(85C,100C)
PS1 Capacity: 1153.32 Watts (27.46 Amps @42V)
PS2 Capacity: 1153.32 Watts (27.46 Amps @42V)
PS Configuration : PS1 and PS2 in Non-Redundant Configuration.
Total Power Available: 2306.64 Watts (54.92 Amps @42V)
Total Power Available for Line Card Usage: 2306.64 Watts (54.92 Amps @42V)
Total Power Drawn From the System: 976.50 Watts (23.25 Amps @42V)
Remaining Power in the System: 1330.14 Watts (31.67 Amps @42V)
Slot power Requirement/Usage :
Slot Card Type PowerRequested PowerAllocated CardStatus
Watts A @42V Watts A @42V
1 WS-X6K-SUP1A-2GE 138.60 3.30 138.60 3.30 ok
2 WS-X6K-SUP1A-2GE 138.60 3.30 138.60 3.30 standby
3 0.00 0.00 0.00 0.00 power-bad
4 WS-X6408A-GBIC 84.00 2.00 84.00 2.00 ok
5 WS-X6408A-GBIC 84.00 2.00 84.00 2.00 ok
6 WS-X6408A-GBIC 84.00 2.00 84.00 2.00 ok
7 WS-X6416-GBIC 118.02 2.81 118.02 2.81 ok
8 WS-X6316-GE-TX 216.30 5.15 216.30 5.15 ok
9 WS-X6248-RJ-45 112.98 2.69 112.98 2.69 ok
Linecard serial eeprom could not be read for module 3
Silver
Re: Catalyst 6509 power-bad status
Hi Lee
"power-bad" indicates that the switch is able to see the card, but unable to allocate power. This is because of the Supervisor Engine is not able access the serial PROM (SPROM) contents on the module in order to determine the identification of the line card.
You have to reset the module.
Use command "hw-module module 3 reset" and let us know.
Hope this helps
Community Member
This command is not available the version of software i am using.
The switch is running ver 5.4(1)
And the MSFC is on 12.1(1)E
Could this possibly be the problem.
Silver
OK. So your catalyst is running in Hybrid mode. Then use "reset 3"
Silver
Lee
Now, I have seen that module requires minimum supervisor engine software version 8.4(1).
So you have to upgrade your Supervisor Engine software in order to support that module.
Community Member
HTH,
Thanks for you time.
465
