Catalyst 6509 Power Issues
I have Catalyst 6509 switch. While doing a routine check i found that it says system minor alarm on power suppy 1 power output failed. I am thinking it is a issue with the first power suppy or its a issue with the twist lock cable. Following is the ouput.
6509#sh environme
environmental alarms:
system minor alarm on power-supply 1 power-output-fail (raised 8w1d ago)
backplane:
  operating clock count: 2
  operating VTT count: 3
fan-tray 1:
  fan-tray 1 type: WS-C6K-9SLOT-FAN2
  fan-tray 1 version: 2
  fan-tray 1 fan-fail: OK
VTT 1:
  VTT 1 OK: OK
  VTT 1 outlet temperature: 25C
VTT 2:
  VTT 2 OK: OK
  VTT 2 outlet temperature: 20C
VTT 3:
  VTT 3 OK: OK
  VTT 3 outlet temperature: 39C
clock 1:
  clock 1 OK: OK, clock 1 clock-inuse: in-use
clock 2:
  clock 2 OK: OK, clock 2 clock-inuse: not-in-use
power-supply 1:
  power-supply 1 power-output-fail: failed
power-supply 2:
  power-supply 2 fan-fail: OK
  power-supply 2 power-input: AC high
  power-supply 2 power-output-mode: high
  power-supply 2 power-output-fail: OK
module 1:
  module 1 power-output-fail: OK
  module 1 outlet temperature: 22C
  module 1 inlet temperature: 19C
  module 1 device-1 temperature: 21C
  module 1 device-2 temperature: 24C
module 2:
  module 2 power-output-fail: OK
  module 2 outlet temperature: 23C
  module 2 inlet temperature: 20C
  module 2 device-1 temperature: 22C
  module 2 device-2 temperature: 26C
module 3:
  module 3 power-output-fail: OK
  module 3 outlet temperature: 22C
  module 3 inlet temperature: 19C
  module 3 device-1 temperature: 21C
  module 3 device-2 temperature: 20C
module 5:
  module 5 power-output-fail: OK
  module 5 outlet temperature: 25C
  module 5 inlet temperature: 18C
  module 5 device-1 temperature: 30C
  module 5 device-2 temperature: 30C
  module 5 asic-1 temperature: 19C
  module 5 asic-2 temperature: 19C
  module 5 asic-3 temperature: 19C
  module 5 asic-4 temperature: 19C
  module 5 asic-5 temperature: 19C
  module 5 asic-6 temperature: 19C
  module 5 RP outlet temperature: 20C
  module 5 RP inlet temperature: 20C
  module 5 EARL outlet temperature: 33C
  module 5 EARL inlet temperature: 18C
module 7:
  module 7 power-output-fail: OK
  module 7 outlet temperature: 31C
  module 7 inlet temperature: 25C
  module 7 device-1 temperature: 20C
  module 7 device-2 temperature: 28C
  module 7 aux-1 temperature: 26C
  module 7 aux-2 temperature: 26C
module 9:
  module 9 power-output-fail: OK
  module 9 outlet temperature: 28C
  module 9 inlet temperature: 18C
  module 9 device-1 temperature: 19C
  module 9 device-2 temperature: 23C
chassis connector rating: 1260.00 Watts (30.00 Amps @ 42V)
module 1
  module 1 connector rating: 1260.00 Watts (30.00 Amps @ 42V)
  module 1 power consumption: 103.74 Watts ( 2.47 Amps @ 42V)
module 2
  module 2 connector rating: 1260.00 Watts (30.00 Amps @ 42V)
  module 2 power consumption: 103.74 Watts ( 2.47 Amps @ 42V)
module 3
  module 3 connector rating: 1260.00 Watts (30.00 Amps @ 42V)
  module 3 power consumption: 103.74 Watts ( 2.47 Amps @ 42V)
module 5
  module 5 connector rating: 1260.00 Watts (30.00 Amps @ 42V)
  module 5 power consumption: 315.00 Watts ( 7.50 Amps @ 42V)
module 7
  module 7 connector rating: 1260.00 Watts (30.00 Amps @ 42V)
  module 7 power consumption: 171.78 Watts ( 4.09 Amps @ 42V)
module 9
  module 9 connector rating: 2016.00 Watts (48.00 Amps @ 42V)
  module 9 power consumption: 125.16 Watts ( 2.98 Amps @ 42V)
chassis per slot cooling capacity: 70 cfm
ambient temperature: < 55C
  module 1 cooling requirement: 30 cfm
  module 2 cooling requirement: 30 cfm
  module 3 cooling requirement: 30 cfm
  module 5 cooling requirement: 35 cfm
  module 7 cooling requirement: 30 cfm
  module 9 cooling requirement: 70 cfm
Can anyone help me figuring this out?
Chetan
Hall of Fame Super Gold
Contact Cisco TAC.  Your PS
Contact Cisco TAC.  Your PS is dead.
This discussion has been
This discussion has been reposted from Community Ideas to the Other Network Infrastructure Subjects community.
56
