Catalyst 6509 + Sup 720 insert in Slot 5.Slot 1 and 2?
Have a Catalsyt 6500 with Sup720 insert into Slot 5.
Can I insert a linecard (WS-X6548-GE-TX) into Slot 1 or 2?
1 REPLY
Bronze
Re: Catalyst 6509 + Sup 720 insert in Slot 5.Slot 1 and 2?
Yes. You can connect any module in any slot in the 6509.
Side note:
For a 6509 you have a two 20Gbps connections (40Gbps) capability in each of the 9 slots (9*40=360Gbps - 720Gbps Full duplex)
For a 6513, you have a single 20 Gb connection for slots 1-8 (8*20=160Gbps) and two 20 Gbps (40 Gbps) connections for slots 9-13 (5*40Gbps=200Gbps)---200Gbps+160Gbps=360Gbps or 720Gbps full duplex.
-HTH
120
