Catalyst 6509 switch GE and FE Modules
Hi All,
On a CAT-6509, when I remove the GE or FE modules from the chassis ,will that configuration on the GE/FE modules disappear and when I insert it back will that configuration is going to reappear ?
Madan
1 REPLY
Re: Catalyst 6509 switch GE and FE Modules
On a Native Mode yes, the configuration for that line card will remain in the running-configuration and therfore the same config will retunr upon insertion of that same line card, it's called "slot provisionining".
Bug id CSCsb49891 is an enhancement to the IOS that clears the configuration of the removed line card or turns off the "slot provisioning".
router(config)#module ?
ContentServicesGateway Configure a CSG module
ContentSwitchingModule configure a CSM SLB module
clear-config To clear configuration when module is removed
provision Configure module provision status
router(config)#module clear-config
The above CLI knob is present in 12.2(18)SXF or above so in your case, you will not have the knob, you need to reload the switch to remove the removed line card's configuration.
Please rate all posts.
162
