Catalyst 6509 system error
We have a Catalyst 6509 switch. Its system LED is continuously orange. Tried to remove and inserting all the modules again (supervieor, IDS, 48 port FE modules). But still the system LED is orage, and when I run the command sh system it shows system status faulty.
I would like to know if anybody has faced this problem, and what could be the probable solution for the same.
(Even the status is faulty I am able to use the switch, but what could be the reason for this LED status)
Sunil
Re: Catalyst 6509 system error
Do you have both power supplies operational? If you have a PS in the chassis which is not connected to a outlet, the system status would show faulty
Thanks for your reply.
Yes, both the power supplies are operational.
Can you paste the output of sh ver, sh system
The problem is resolved.
I removed both the power supplies and reinserted. It worked.
However both the PS were showing green LEDs and their status was ok.
Thanks for your help.
Sunil
136
