Catalyst C2900XL Console Port Problem
Dear Internetworkers,
I've got a C2924XL switch which I am having difficulty having my console connection to issue commands. I can see it booting up and asking for "Press RETURN to get started!" but when I do nothing happens. I tried password recovery and it is still the same it just sits at the "switch:" prompt and does not respond back.
I have tried the standard 9600-8-Non_1 and almost all combinations of COM1 setting with speed parity stop bits etc but no luck.
Could someone please help?
Below is a copy of the standard outputs while the switch is booting;
C2900XL Boot Loader (C2900-HBOOT-M) Version 12.0(5.2)XU, MAINTENANCE INTERIM SOF
TWARE
Compiled Mon 17-Jul-00 18:19 by ayounes
starting...
Base ethernet MAC Address: 00:04:c1:44:00:00
Xmodem file system is available.
Initializing Flash...
flashfs[0]: 109 files, 3 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 3612672
flashfs[0]: Bytes used: 2778112
flashfs[0]: Bytes available: 834560
flashfs[0]: flashfs fsck took 6 seconds.
...done Initializing Flash.
Boot Sector Filesystem (bs:) installed, fsid: 3
Parameter Block Filesystem (pb:) installed, fsid: 4
Loading "flash:c2900XL-c3h2s-mz-120.5.2-XU.bin"...##############################
File "flash:c2900XL-c3h2s-mz-120.5.2-XU.bin" uncompressed and installed, entry p
oint: 0x3000
executing...
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
IOS (tm) C2900XL Software (C2900XL-C3H2S-M), Version 12.0(5.2)XU, MAINTENANCE IN
TERIM SOFTWARE
Copyright (c) 1986-2000 by cisco Systems, Inc.
Compiled Mon 17-Jul-00 17:35 by ayounes
Image text-base: 0x00003000, data-base: 0x00301F3C
Initializing C2900XL flash...
flashfs[1]: 109 files, 3 directories
flashfs[1]: 0 orphaned files, 0 orphaned directories
flashfs[1]: Total bytes: 3612672
flashfs[1]: Bytes used: 2778112
flashfs[1]: Bytes available: 834560
flashfs[1]: flashfs fsck took 7 seconds.
flashfs[1]: Initialization complete.
...done Initializing C2900XL flash.
C2900XL POST: System Board Test: Passed
C2900XL POST: Daughter Card Test: Passed
C2900XL POST: CPU Buffer Test: Passed
C2900XL POST: CPU Notify RAM Test: Passed
C2900XL POST: CPU Interface Test: Passed
C2900XL POST: Testing Switch Core: Passed
C2900XL POST: Testing Buffer Table: Passed
C2900XL POST: Data Buffer Test: Passed
C2900XL POST: Configuring Switch Parameters: Passed
C2900XL POST: Ethernet Controller Test: Passed
C2900XL POST: MII Test: Passed
cisco WS-C2924-XL (PowerPC403GA) processor (revision 0x11) with 8192K/1024K byte
s of memory.
Processor board ID FAB0453V0AB, with hardware revision 0x01
Last reset from power-on
Processor is running Enterprise Edition Software
Cluster command switch capable
Cluster member switch capable
24 FastEthernet/IEEE 802.3 interface(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:04:C1:44:00:00
Motherboard assembly number: 73-3382-08
Power supply part number: 34-0834-01
Motherboard serial number: FAB045282QD
Power supply serial number: DAB04353U0F
Model revision number: A0
Motherboard revision number: C0
Model number: WS-C2924-XL-EN
System serial number: FAB0453V0AB
C2900XL INIT: Complete
00:00:28: %SYS-5-CONFIG: Configured from NVRAM by console
00:00:28: %SYS-5-RESTART: System restarted --
TERIM SOFTWARE
Re: Catalyst C2900XL Console Port Problem
I suppose your terminal and cable are OK (are you able to connect to another switch with them?).
So there might be something wrong in the config.
I'd try
1) connect the switch to another switch by a cross cable and see if there is a CDP coming.
If yes, you should be able to get the switch IP address (by sh cdp nei details on the other switch)and try to telnet to it (unless there is an ACL preventing it in the config - do you know anything about the config content?).
2) If you are not successfull with 1), try the password recovery procedure (http://www.cisco.com/warp/public/474/pswdrec_2900xl.pdf) steps 1.-3. and you should be able to communicate with the switch via console then. If not I would consider a HW problem on the console port.
If yes, continue password recovery procedure to see whats wrong in the config (rename the config file and reboot the switch).
Milan
The problem was the IOS version, upgrade your Switch.
I found the same problem on the same version (12.0.(5.2)XU.
I put "login" on line con 0, I can access on time after reboot, but, the other times I can't !
143
