Community Member
Catalyst sending 60-Bytes frame to itself (ethertype 0x9000)
observed in our Catalyst-based network that the switches are sometimes sending "Loopback"-Packets
(Ethertype 0x9000) to its own MAC-Address. 46-Bytes Data contain only zeros.
Does anybody know what the switch is doing with this frame ?????
Kind Regards
Hubert
Re: Catalyst sending 60-Bytes frame to itself (ethertype 0x9000)
Hubert,
These packets are used, as you say, for loopback purposes. The switch, and most other cisco devices use these packets to check wheter the LAN interface is operational (up) or not.
Leo
Community Member
Hi Leo,
how will the switch dedect if the interface is up by sending such a packet out for example through a port
where a workstation is connected. The Workstation will not send back the loop-frame, true ??
Kind Regards
Hubert
Herbert,
It simply listens to its own transmissions.
When it receives a datagram with its own mac adress it knows the TX and RX leads on the LAN are both operational.
Leo
363
