Catalyst Underruns/Output Buffer Failures
I can't find any information (bug Navigator, technical tips, CCO documentation, etc.) which I understand about Underruns in the output of the command
"show interface FastEthenet 0/X" for a Catalyst 3500XL.
I have the next output in some of my ports:
HQ-SW#show interface
FastEthernet0/47 is up, line protocol is up
Hardware is Fast Ethernet, address is 0002.b9cd.822f (bia 0002.b9cd.822f)
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
Keepalive not set
Auto-duplex (Full), Auto Speed (100), 100BaseTX/FX
Last input never, output 00:00:01, output hang never
Last clearing of "show interface" counters 1d00h
Queueing strategy: fifo
Output queue 0/40, 0 drops; input queue 0/75, 0 drops
5 minute output rate 4000 bits/sec, 4 packets/sec
154735 packets input, 29142807 bytes
Received 284 broadcasts, 0 runts, 0 giants, 0 throttles
0 watchdog, 0 multicast
245598 packets output, 23693638 bytes, 1019 underruns
0 lost carrier, 0 no carrier
1019 output buffer failures, 0 output buffers swapped out
I can't understand why I'm having Underruns and for this I assume are the output buffer failures.
Does Underruns meant those frames that the switch port can't handle because it hasn't buffers?
what are causing in this case overruns?, there isn't any excesive utilization with this switch port, very low indeed, or any speed mismatch, and you can see only 280 broadcasts.
Re: Catalyst Underruns/Output Buffer Failures
Often times complex troubleshooting issues are best addressed in an interactive trouble-shooting session with one of our trained technical assistance engineers. While other forum users may be able to help, it’s often difficult to do so for this type of issue.
To utilize the resources at our Technical Assistance Center, please visit and to open a case with one of our TAC engineers, visit
If anyone else in the forum has some advice, please reply to this thread.
Thank you for posting.
