Webcast-Catalyst9k
CATALYST2950SX - speed 1000 nonegotiate
Is it possible to turn off speed negotiation on the giga fiber port? There is no SPEED option.
Re: CATALYST2950SX - speed 1000 nonegotiate
If the version is earlier than 12.1(6)EA2 you need the 'no negotiation auto' command under the gigabit port.
For later versions you must use 'speed nonegotiate'
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat2950/12111yj/cr/intro.htm
There is no SPEED NONEGOTIATE option and there no NO NEGOTIATION AUTO option.
Software ver.:12.1(13)EA1b
Sorry, the above commands are for 10/100/1000 ports but do not include the GBIC interfaces. Please refer to the following link.
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat2950/12113ea1/2950scg/swint.htm#41645
It seems that you cannot set speed on GBIC interfaces and only a few support auto duplex
360
