11-11-2003 09:08 AM - edited 03-02-2019 11:38 AM
I am running a 6513 with CatOS 7.6(2), authenticating using tacacs+. Authentication works fine and I am pretty familiar with the configuration aspects of tacacs+. I am trying to allow users level 15 access upon being authenticated (this works fine on IOS), but it does not work on CatOS.
I can add the command "set authentication enable tacacs enable" or the command "set authorization enable enable tacacs none", but after successfully logging in (using tacacs), I am not in priviledged mode and if I type "enable", I then have to provide my tacacs+ password again in order to get to enable mode.
The tacacs+ server is configured to allow priviledge level 15 as well as tacacs+ enable. ACS version is (3.0.2.5)
Bottom line: Is there a way to have CatOS drop you into level 15 or enable mode after a successful authenication using tacacs+ ??
Thanks in advance.
Scott
Solved! Go to Solution.
11-11-2003 12:04 PM
Scott,
Try this. It worked for me on the 6500 platform (although with an older version of code):
set authentication login tacacs enable all primary
set authorization exec enable tacacs+ none both
Rich
11-11-2003 12:04 PM
Scott,
Rich
