Webcast-Catalyst9k
CatOS upgrade on 4006 sup same as Cat6500?
Are the steps to upgrade the CatOS running on a 4006's Supervisor the same as those for doing a 6500 running CatOS on the sup? I'm having trouble finding detailed steps on doing the 4006's upgrade, but have detailed steps for the 6500 (with CatOS on the Supervisor)
1 ACCEPTED SOLUTION
Silver
Re: CatOS upgrade on 4006 sup same as Cat6500?
Silver
Purple
If you have a tftp server to download from it is simply "copy tftp bootflash: " , it will ask you what the name of the file is and the ip of the server , then it will just download to bootflash. Change your boot statement after downloading , "set boot system flash bootflash: prepend . This will put the new boot statement ahead of any other configured boot statements or you simply get rid of the old boot statement first "clear boot system all" , then add your boot statement.
133
