05-17-2003 06:51 AM - edited 03-02-2019 07:25 AM
Pardon me if this topic has been discussed before, but is it true that Cisco is phasing out CatOS switches, and that all switches will be IOS down the road?
I need to buy another switch for my home lab and the answer to the above will tell me what I should get :)
TIA
Solved! Go to Solution.
05-17-2003 06:59 AM
The only switch where you have a choice of CAT OS or IOS is the Catalyst 6000 family(Sup1a/Sup2). All other switches are switches are either IOS based or CAT OS based(Sup3/4 for CAT4006 runs IOS only). We have not announced End of life or End of Sales on CAT OS and we are still coming out with new CAT OS releases.
If you are buying a switch for home, I'm assuming you would be going for a smaller fixed chassis switch such as 2950 or 3550 which run IOS only
05-17-2003 06:59 AM
05-17-2003 07:16 AM
Thanks for your speedy reply. Hmmm this is interesting; some other 'inside sources' have indicated that CatOS will be phased out. I could be wrong about this and regardless, Cat OS switches are predominantly deployed all over the market right now.
I already have a 2924XL and want to add another switch, to do trunking etc. I am considering either a 5505, 2950 or a 3550. I would like to get a switch that gives me maximum functionality to prepare for CCIE. Which one would you recommend?
TIA
05-17-2003 02:14 PM
I believe the 3550's are used in current CCIE lab exams.
05-17-2003 05:08 PM
yep, thanks...
