CBWFQ and IPX possible ?
m.baker
Is it possible to use CBWFQ for other protocols then IP ? IPX for example ?
I'd like to use CBWFQ for IP and IPX traffic. Then to do WRED in the Classes of IP traffic and have my default class do per-flow WFQ....
Is this possible ?
CBWFQ for IPX is possible, provided, of course, that you have an IPX feature set loaded :)
class-map ipx
match protocol ipx
Check the following link for CBWFQ supported protocols and options in version 12.0(5)T:
http://www.cisco.com/univercd/cc/td/doc/product/software/ios120/120newft/120t/120t5/cbwfq.pdf
Georg
class-map ipx
match protocol ipx
Georg
