I have three classes define in CBWFQ. The class with the most traffic (batch transfers) is only allocated 10% of bandwidth, while real time/interactive traffic is allocated to a class which gets 65% of bandwidth. When the batch transfer class gets a lot of traffic, I see lots of packet drops in that class. So far so good,as this is the traffic that I want to be penalized. The interactive traffic class however still sees a relatively high number of drops for the little traffic it has to sends. I would think that the interactive class would not drop packets unless it needs to use more then 65% of bandwidth....Is this normal behavior ? If so, how can it be explained ? The policy is attached to an ATM OC3 interface on a 7500 router. Seems like the weight provided by the bandwidth statement is not enough to avoid drops for the interactive traffic.
