Community Member
CBWFQ : Not supported on subinterfaces - QOS problem
I have c2610xm router with 64/32 memories. Software is 12.2(11)T9. WIC = G.SHDSL
I have class-maps and policy-maps configured ok, but then I try to write service-policy output-command into ATM-pvc - i get that notice = CBWFQ : Not supported on subinterfaces. What to do ?
Re: CBWFQ : Not supported on subinterfaces - QOS problem
Community Member
I have found that page earlier, but that was not answer - I have tried to put service-policy output command under pvc, not under subint as there is advised. I think this is bug in software 12.2(11)T9, I found two more routers with same software and same router. I try to fix that problem through updating software to 12.3.1. Let us see if it helps.
Thanks for your fast answer !
250
