CBWFQ on ATM Subinterfaces (or not)
Congestion Management Overview (CCO) states that 'CBWFQ is not supported on subinterfaces'.
Other CCO documents indicate that it can be done on Ethernet subinterfaces, and on 'subinterfaces' in general.
Can it or can't it?
Bronze
Re: CBWFQ on ATM Subinterfaces (or not)
Mat,
It can be done. More information can be found at:
http://www.cisco.com/warp/public/121/7200_per-vc-CBWFQ.html
-Zach
Spot on.
One last question... the document you referenced states that Per-VC CBWFQ is available on 2600/3600 with IOS 12.0(7)T or above.
Is it safe to assume that the NM-4E1-IMA is supported or is there a method of checking...
Mat
Bronze
Mat,
12.0(7)T supports the NM-4E1-IMA. You can always verify here:
http://www.cisco.com/cgi-bin/front.x/Support/HWSWmatrix/hwswmatrix.cgi
-Zach
127
