CBWFQ questions
m.baker
Can somebody help me answer the following ?
1) If I have 2 class under a CBWFQ policy and one of the 2 is the class-default which I configure for fair-queue. WHat will happen under congestion if the other queue has a bandwidth percent 10 statement ? Will the class-default get 90% of the bandwidth ?
2) If I use CBWFQ along with FRTS, is there a way I can display with a show command the flows I have under the class-default fair-queue ? I was able to do this with WFQ applied to the interface without FRTS...but now with FRTS AND CBWFQ I can't find a way to display the flows in the class-default ...
Not applicable
Robert Saurer
I've the same problem. I don't know how to find out the max-active flows and active flows for Flow-based WFQ configured under the class-default class in CBWFQ.
Robert
