ccie equipment
I prepare for ccie exam.I want to buy some equipment for it.I don't know how to do it.pLease give some advice on how to buy it.I will thanks a lot.
Silver
Re: ccie equipment
Cisco partners or distributors should have the required equipment...but guess that will be an expensive exam preperation., maybe some Cisco training institute can offer soem advice.
Thanks, Mak.
Re: ccie equipment
Buying equipments is definitely an expensive thing to do, but i would say the best place to check out is ebay.com. Except for VoIP, ATM etc, u should be able to test and study almost all routing protocols and layer 2 technolgies, using 2500 routers, which are the cheapest available at ebay. 2600s would be ideal to practice on atm and voip.
Hope that helps!
82
