I have set up a lab to look at F/R with a partial mesh and sub-interfaces.
I have 3 DTE routers connected to a Frame Switch. One Router named 'middle' has the sub-interfaces configured on it. The other 2 routers named 'Top' & 'Bottom' are just physical interfaces.
I used RIP to route the two networks between Top & Middle and Bottom & Middle respectively. The F/R side has gone well, however, CDP switched itself off on both of the physical interfaces on routers Top & Bottom !!!
Is there a good reason for this ?
To rectify this I have simply enabled cdp on both the serial interfaces.
Phil.
