How can you enable cdp on just the sc0 interface? Our private(management) connection is plugged into the mgmt port on the supervisor. So how do you specify that port, if you can? Thanks.
Your query is like asking, 'how do I enabled cdp on interface vlan 1'.
CDP is enabled on physical interfaces, by default.
