Community Member
cdp on sc0 interface
How can you enable cdp on just the sc0 interface? Our private(management) connection is plugged into the mgmt port on the supervisor. So how do you specify that port, if you can? Thanks.
1 REPLY
Hall of Fame Super Bronze
Re: cdp on sc0 interface
sc0 is a logical interface
Your query is like asking, 'how do I enabled cdp on interface vlan 1'.
CDP is enabled on physical interfaces, by default.
199
