Webcast-Catalyst9k
CE-500 switches
Does the new catalyst express 500 series switch support VLAN - dot1q
Re: CE-500 switches
Sure, they support
JD
Re: CE-500 switches
Sanjeev,
CE500 does support 802.1q. You can find relevant documentation about this, under Product Specifications in this link.
http://www.cisco.com/en/US/products/ps6545/products_data_sheet0900aecd80322aeb.html
Re: CE-500 switches
to configure qos for voip, I read that I only have to configure cisco voice
vlan ? Is it enough ? Is it possible to change some qos setting with the web
interface ?
3560 or 3750 are not a better choice for POE toip access switches, because they
have ios cli commands. Thank you for helping me.
190
