Community Member
CE500 problem with IE6
I cannot assign an IP adress to 2 CE500 switches from one laptop running XP SP2 but I can from another one... There seem to be a problem in the IE scripting section on one laptop since it report scripting error for a lot of panel on CE500 config pages (ipMode has Null value, Hostname.lenght has null value)... It won't event display data in the Switch Information Section on the dashboard page... I can add the login account but it look like it refuse the IP address...
I have change security parameters, make sure there is no antipopup, firewall but nothing seem to work
Any idea?
1 REPLY
Silver
Re: CE500 problem with IE6
Do you receive any error message if you try to assign the ip address to those 2 switches?. If yes, then can you send me a snapshot of that error message?. This will help me in precisely pointing out the reason for this problem.
98
