09-11-2003 10:30 AM - edited 03-02-2019 10:16 AM
We have a point-to-multipoint frame relay configuration with CEF enabled. Should we still use the 'ip route-cache same-interface' command to reduce the process switching of site to site traffic?
09-11-2003 10:57 AM
All configured on a single multipoint interface, or configured as subinterfaces? If they are on subinterfaces, you shouldn't need this. If they are on one interface, then I would turn it on.
Russ.W
09-11-2003 12:16 PM
It is a single interface (ospf point-to-multipoint).
09-12-2003 02:30 AM
Then you'll need to turn on route cache same interface.
Russ.W
